My windows were a bit high and were ripping the rubber at the top where it meets the quarter light so I decided to sort it out.
This adjustment stands for the MK 1 1989 >1997.......Mk 2 1998 > 2000......Mk 2.5 2001 > 2005, the only difference being that the door trims are different to remove.
All you'll need is a cross head screwdriver & 10mm socket & ratchet
Remove the clips by pulling out the center part then wiggling until they come out.
Unscrew all the screws & put to one side.
There is a piece of trim carpet that needs to be lifted to give access to the bottom screw on the arm rest ( Note:- the bottom screw that holds the door pull handle in place on the Mk.2.5 is found in the base of the bottom of the handle not here like the MK 2 version)
Now pull the door card away from the door (you'll hear the studs un-click) you need to do this at both sides & the bottom
Then lift the whole card so it comes away from the top edge.
Be careful you'll need to disconnect the tweeter if you have one
Now you can put the door card to one side out of the way.
Pull the membrane away from the door. (messy black stuff)
All along the top edge like so.
Now operate the window so the top of the glass is exactly where it should be
Now you can loosen the first adjusting bolt. Which is located as shown here. (second hole in from the outer edge of the door)
Now loosen the second bolt Fifth hole from the outer edge of the door)
You need to now wiggle the bolt & you'll see & feel the rubber coated window stop touch the stopper on the side window glass (this is where it needs to be) Lock up both bolts in that position.
It will become obvious when you look down between the glass & door.
Then put everything back in reverse order after sticking the membrane back into place.
Adjusting Windows Mk 1/2/2.5
Postby flea » Sun Sep 07, 2014 1:49 pm
Return to “Soft top/ Hard top/windows”
Jump to
- The Board Room (Administration)
- Mazdamenders.net donation button
- Contact Us
- The Reception (General)
- Welcome desk
- Rules & Regs
- Forum How Tos
- MazdaMenders Shop...of all things great
- Promotions and special offers
- The technical Help desk
- Problems
- The Show Room
- Members Mx-5/ Roadsters
- The Waiting Room
- Mx/Roadster Chat and Banter
- ARCHIVE:- Mx/Roadster Chat and banter
- Non Mx/roadster general car topics
- ARCHIVE:- General car topics
- General chat and banter
- ARCHIVE:-General chat & banter
- Birthdays and general well wishes section
- Chuckle Box
- RANT! Not for the faint hearted!!!
- ARCHIVE:- Rant topics
- FaceBook links
- The Information pin board
- Mazdamenders.net Tech days
- Events & meets
- ARCHIVE:Event topics
- Games & competitions
- Site News
- Our aim and goals....
- Mazda Recalls/call backs/warnings
- The Service Department (Hands On)
- Maintenance
- MK1 -1989 > 1997 (NA)
- MK2/2.5 - 1998 > 2000/ 2001 > 2005 (NB)
- MK 3/3.5 2006 > 2015 (NC)
- Mk 4, 2015 to date (ND)
- Auto's ....all marks 1989 to date
- Modifications
- MK1
- MK2
- MK3
- Auto's
- Your mods
- recommended tools/ must haves/bargains
- The Body Shop Department
- Deepcar Autobodies..... sheffield
- General Body shop
- Cleaning & Detailing
- The Tuning & Boosting Department
- Rolling Road (Extra boost, POWER )
- Superchargers
- Turbo chargers
- Mazdamenders you tube channel
- Mazdamenders you tube channel..
- You tube tech/guide vid links
- You tube racing Vid links
- You tube car stuff vid links
- You tube funny/stupid/miscellaneous vid links
- The Workshop servicing manuals (How To's & FAQs)
- MK 1 1989 to 1997 ( NA)
- Interior
- ICE(audio) and electrics
- Audio(Head units) and speakers
- Electrics
- Trim
- Exterior
- Engine....1.6/1.8 SNC/LNC, transmission and electrics
- Engine
- Transmission and drive train
- Electrics
- Exhaust
- Clutch
- Handling,steering, suspension, wheels,Tyres
- suspension
- steering
- Wheels and tyres
- Braking
- Soft top/Hard top/windows
- Lights and eletrics
- Body panels and accessories
- Maintainence/servicable items
- Heating and cooling
- Mk 2/2.5 1998 to 2005 (NB)
- Interior
- Trim
- Electrics
- Exterior
- Engine....1.6/1.8 ,transmission and electrics
- Engine
- Transmission and drivetrain
- Electrics
- Clutch
- Handling,Steering,Suspension,Wheels,Tyres
- Suspension
- Steering
- Wheels and Tyres
- Braking
- Soft top/ Hard top/windows
- Lights and Electrics
- MK 3/3.5 2006 to 2015 (NC)
- Interior
- Audio(Head units), speakers and Electrics
- Audo and speakers
- Electrics
- Trim
- Exterior
- Engine 1.8/2.0, Transmission and Electrics
- Engine
- Electrics
- Handling, Steering,Suspension,Wheels,Tyres
- Suspension
- Steering
- Wheels and Tyres
- Braking
- Soft top/Hard top
- Miscellaneous (NA/NB/NC/ND)
- Identifying the differences between the most common parts.
- Catastrophic Chris's Poorly Mx-5/Roadster problems
- Top Tips
- NA,NB,NC,ND specs and versions 1989 to date
- JDM NA,NB,NC,ND specs/versions 1989> to date
- JDM MK 1 NA Eunos Roadster Specs 1989 > 1997
- JDM Mk 2 NB Roadster specs 1998 > 2000/01
- JDM Mk2.5 NBFL Roadster specs 2001 > 2005
- JDM MK 3/3.5/ 3.75 NC specs 2006 > 2015
- JDM MK 4 ND specs 2016 to date
- UK Mx-5 NA,NB,NC,ND specs/versions 1990 to date
- UK Mx-5 Mk 1 NA specs 1990 > 1997
- UK Mx-5 MK 2 NB specs 1998 > 2000/01
- UK Mx-5 Mk 2.5 NBFL Specs 2001 > 2005
- UK Mx-5 Mk 3/3.5/3.75 NC specs 2006 . 2015
- UK Mx-5 Mk 4 ND specs 2016 to date
- U.S Miata NA,NB,NC,ND specs/versions to date
- U.S Miata Mk 1 NA specs 1998 > 1997
- U.S Miata MK 2 NB specs 1998 > 2000/01
- U.S Miata MK2.5 NBFL specs 2001 > 2005
- U.S Miata MK 3/3.5/3.75 specs 2006 > 20015
- U.S Miata MK 4 ND specs 2016 to date
- Miscellaneous (NA/NB/NC/ND) brochures form around the world
- Test driving
- Track / Racing
- ARCHIVE:- Track / Racing
- Accessory Catalogues
- Jass performance
- Matthews accessory corner
- Mx5 Tech
- Mx5.fixes.com
- Binarypunk mods & products
- Mazda Bongo
- Miscellaneous Co's of interest
- Traders Section
- Autolink
- Goodwood Sports Cars
- Stokes of kelsey
- Furious fives
- Classifieds
- Auto jumble
- Items For Sale
- Mazda Menders bat cave clear out
- Wanted
- The forecourt (Mx-5/roadsters)
- The swap shop
- Parts Department
- Autolink specials.........
- Insurance
- Adrian Flux Insurance
- The Toilets
- Sin Bin
- Stupid questions and threads archive
- The spotted threads
- The Breakdown help desk
- Mazda-Menders Mx-5 5th Emergency service Volunteers for Mx/roadster owners,,,,
- Feedback Box
- Your Suggestions
- ARCHIVE:-Suggestions
- Complaints Department (Site Problems)
- ARCHIVE:-Site problems
