Dinitrol RC900
ne.ross
Dinitrol RC900
Postby ne.ross » Sun Mar 06, 2016 4:09 pm
Has anyone used this product? what is it like? Are there better alternatives out there?
I have removed the old underseal from the wheel arches and i have wire wheeled the surface rust out but there is some pitting with rust in that I need to sort out.
Red 2003 MK2.5 S-VT Sport
drumtochty
Re: Dinitrol RC900
Postby drumtochty » Sun Mar 06, 2016 4:45 pm
It's a last resort product.
If you have bad surface rust but not all the way through.
Rub down
Rust Convert
Prime
Topcoat
If required underseal.
That is what most people including Dinitol say is the best method.
If you have a cavity that you cannot work in due to access problems, you spray the Dinitrol RC900 goo in there onto the rust. Dinitrol advises that it will stop the rust and seal it from getting worse.
I think at best it will slow things down.
Therefore only use it in areas you cannot access, not areas that you can get at the rust.
2008 Mk3 Copper Red
Re: Dinitrol RC900
Postby Mazda Mender » Thu Mar 10, 2016 8:16 am
It's good stuff and will do the job, but like any product it is only any good if the prep work as been done correct, i personlly like Schutz.... http://www.ebay.co.uk/itm/6-x-3M-Car-Bo ... xyaTxTR-kS.
But as with them all , just doing the outside is a waste of time, the box sections need doing to if they are in good condition , if they are on the way out then get them repaired correct first and then kill them with the stuff, if they are rotten and they get covered then you are again wasting your time plus it will make it harder for the repairer to repair them.
ne.ross
Re: Dinitrol RC900
Postby ne.ross » Thu Mar 24, 2016 10:16 pm
thanks for the replies, i sprayed the arches with RC900 and it converted the few patches black and there was no rust left on show. None of the places that had rust let the screw driver go through so Im hoping it was just surface rust that was from the old flaking underseal
MartyM
Re: Dinitrol RC900
Postby MartyM » Fri Dec 15, 2017 4:14 pm
I use this for inside sills/chassis rails
MartyM
Re: Dinitrol RC900
Postby MartyM » Fri Dec 15, 2017 4:17 pm
This stuff is not bad for protecting wheel arch lips & spraying on suspension arms etc
Re: Dinitrol RC900
Postby blackyb » Fri Dec 15, 2017 8:48 pm
MartyM wrote:Image
Who stocks this product??
MartyM
Re: Dinitrol RC900
Postby MartyM » Sat Dec 16, 2017 11:06 am
Last few lots I have purchased via ebay. the more you buy the cheaper works out at about ÂŁ6 a tin. I normally use an extension tube with spray nozzle on end to get into sill etc.
Re: Dinitrol RC900
Postby blackyb » Sat Dec 16, 2017 3:32 pm
Cheers, will have a gander on the bay of all Es later.
:text-thankyouyellow:
Re: Dinitrol RC900
Postby Mazda Mender » Sun Dec 17, 2017 9:26 pm
Bry, you do know that is not dinitrol.
Re: Dinitrol RC900
Postby blackyb » Mon Dec 18, 2017 3:09 pm
Yep, its not for the MX, its for our lasses fezza
MartyM
Re: Dinitrol RC900
Postby MartyM » Mon Dec 18, 2017 6:15 pm
Some info on Supertrol
Supertrol 001 anti rust spray is a penetrating rust proofing fluid, which prevents rust and does not contain silicone. Supertrol 001 stops internal rust and offers a protective coating that stays flexible and is compatible with existing vehicle protection waxes. Supertrol is ideal for corrosion protection of steel components in storage or in transit. A single application of the product by spray or brush will give corrosion protection to metal. Always ensure that metal parts are clean and dry. Spray the component and let dry before handling. The duration of effective corrosion protection will vary with atmospheric and storage conditions, reapplication will extend the protective period. Regular inspection of the treated surface is advised. Supertrol can be removed with normal industrial solvent products. Supertrol is a corrosion preventive material. It is intended primarily to inhibit corrosion in motor vehicle box sections, sill panels, door frames etc., It is suitable for farm equipment and industrial steelwork where a temporary/easily removed coating is required. Supertrol dries to a soft film water repellent coating which resists cracking. Supertrol is vibration resistant and is therefore suitable for commercial vehicles and equipment.
