My 1.8 MK3.5 has just gone out of warranty and I'm looking to learn some maintenance skills by doing some things myself. Does anyone have any does and don'ts for what to do myself? I'm looking at starting with basics such as filters, fluids and brake pads and leaving the bigger jobs (coilovers) to the professionals!
Also what fluids do people recommend for engine, brakes and gearbox/diff?
Sorry if this seems a bit simple minded and noddy, but I've never really had the opportunity to tinker with the car before now and don't want to do something that will harm my pride and joy!
Thanks
Elliott
General Maintenance Help!
Re: General Maintenance Help!
Service items you can get from Andrew at Autolink with the discount off here, Servicing is simple enough, as long as you have the correct tools and being safe...
60,000 is plug change
air filter each year or miles
5/30 fully synth 5ltrs each year or miles
Oil filter each year or miles
I good check over, and thats about it, oil filter can be a pain as you need to get it from underneath and remove the shield, chain (timing) is when it becomes noisey, so years and years away, waste a good couple of tins of silicon lube spray on all the rubber joints etc, And check the drop links as they are a really poor design and last around 2 years.
.M-m
.M-m
Okay thanks very much! I will just make sure I take my time and hopefully all will be okay!
Elliott
Elliott
The scuttle grommets just below the wipers can need resealing, if so buy new ones and replace and use some bathroom silicon sealer.
They can leak on to the electrics underneath and cause havoc.
Antifreeze is 12 year change but brake fluid still needs changed every two years takes a bit more than a litre of Dot4.
Rear calipers need the pistons wound in for new pads do not try to force them in, a wind in tool is handy and the pin on the pad backplate goes into the top of the cross in the piston.
Not the case with the front calipers, the pistons on them just push in after a pad change
Mkae sure the slide pins have plenty read rubber grease not coperslip that is for the lugs on the sides of the backplate.
eddie
eddie
2008 Mk3 Copper Red gone
2018 Mk4 GT+ Red
2018 Mk4 GT+ Red
Thanks very much for the info Eddie! Do you have any preferences/recommendations for brands of brake fluid or oils? Was thinking of using Castrol GTX or Magnatec for the engine, but I have no clue for any others!
Elliott
Elliott
Those oils will be fine buddy, as long as the brake fluid is the right DOT rated there is no preference really on make, as for the 12 year antifreeze? i will look into that.
I really appreciate the advice, can't wait to get started now!
Elliott
Elliott
