Anyway Jon'o i have a major problem myself , the LEDs on one bit of the aftermarket 2.5 headlight units as started to flash, now i have had a look and there is which looks like a small control box? the other half of the light units as another, how can i stop them from flashin as the are side lights and it looks F***ing stupid.
As you can see it is a major problem ;0)
Dodgy LED's ,I need your help Jon'o
- binarypunk
Re: Immobilisers
Are they flashing regularly or randomly? can you make them flash by tapping the light?
http://www.binarypunk.co.uk
Need spares? Go to Autolink!
http://www.autolinkuk.co.uk/
Re: Dodgy LED's ,I need your help Jon'o
I will have my lad catch a vid of whtas happening, to be honest i do not think it is the LED's at fault but the little box modular,which i guess is a voltage convertor? as ther are 3 grom the box doing the same thing, the other two on a different box but using the same connection plug are fine.
I have checked for water, break in a wire etc all is good, fine on start up ,solid , but 20 minures later when i arrive at work they are flashing and then solid and start flashing again in a ramdom;ish order.
Andrey sells these aftermarket units also.
- binarypunk
Sounds very much like a sketchy bit of solder on a circuit board. How handy are you with a soldering iron??
binarypunk wrote:Sounds very much like a sketchy bit of solder on a circuit board. How handy are you with a soldering iron??
Oh i am the best of the best buddy i am ok with soldering Jon, but before i cut open the modual/voltage converter? i need to make sure that that is the problem as she is the everydayer.
- binarypunk
If it's just one of the LEDs in the light...probably not, it's probably the circuit board on the bulb...which is likely to be verrrry tiny bits of solder.
If it's all of the LEDs on that side, maybe the box. The best way to be sure is to swap the boxes over if poss.
Return to “Binarypunk mods & products”
