This is a 100% testing tool to find a dead ABS sensor, the warning light can be misleading as can the fault codes...
First you will need a new or s/hand working ABS sensor, it really does not matter if it is the front or back as long as it works and is complete with the loom and plug, if it is a front one you will need a sensor side rear plug from a scrapper, if it is a rear you will need the sensor side front plug also..
The one we will be using for this guide is a rear ABS sensor with the loom and plug and is a s/hand OE sensor that is fully working which we also have a front sensor plug and a bit of loom....
Rear sensor plug...
Front sensor plug...
Remove all the sensor brackets off the loom....
Next mark up where we are going to be joining the extra plug to the sensor loom and strip the outer core back.....
Strip some cable back on each wire to reveal the copper core to join the extra plug to, in this case we are soldering in because it is a more solid join, you can use crimp connections for this but soldering makes more sense, once soldered, cover the soldered joins with electrical tape...
Get the trunking that was left and cut it down the middle...
Add the trunking to the extra added sensor plug...
Get your electrical tape and tape up and seal the wires and trunking that as been added....
Very simple testing tool to make, just un plug the sensors on the Mx-5/Roadster one by one plugging in the tester until the dial clusters warning light goes out and you have found the faulty sensor that needs replacing.
Any questions , please feel free to ask.
How to make a ABS tester
Re: How to make a ABS tester
Ace write up and a cracking idea. Obviously easier to use a rear sensor as the fronts are usually destroyed removing them and leaving the hub housing on your nice tester may be a bit cumbersome
MK1 '89 (Shell for Project MK1.2.5 - Originally classic Red, resprayed badly in Ford ST Orange, currently being stripped back for respray)
MK1 '94 UK White 1.6 (First Mx-5, now used for track days, will be kept and handed down to my boy)
MK1 '95 Eunos 1.8 Type II Silver Stone Mica S-Package
MK2 '99 10th Anniversary (Reg:FI I0AE - Flyin Miata Turbo)
MK2 '99 Sport Special Edition - A Future Resto Project
MK2.5 '03 sport - Splash Green (Donor running gear/Interior for MK1.2.5 project, shell now scrapped)
Gone but not forgotten
MK2 '99 10th Anniversary (reg:R 10AE - donated to and restored by my bro)
DO NOT try to remove the holding bracket from the sensor, it will kill the sensor.
- New
Excellent job, could i suggest shrink-wrap though instead of tape.
SmokeJaguar wrote:Excellent job, could i suggest shrink-wrap though instead of tape.
Whatever you think works for yourself.
