sill repair on your drive
This is the section to see what is hidding behind those panels, and how to get rid of the tin worm, cutting out and welding in fresh metal, protection and paint.
penarthmx5mark
Postby penarthmx5mark » Fri Jun 14, 2013 9:56 pm
I do all my work on my drive and this is just a quick guide to show how jo blogs can repair their sills without going to the big boys.
first of all you need to find all the rot and cut it out.
After cleaning out all the rot and drill wire brushing i then give 3 good coats of rust eater sealer
A metal patch is cut and shaped i use metal sheet from my local factors it cost next to nothing and welds well
I then shap it over a rubber mallet with another rubber mallet till its just right.
keep holding it up to the hole until the patch just fits on the hole you have cut
I then use strong pc hard drive magnets to hold it secure while i take it into place
here you can see the plate welded into place and ground back to give a smooth finish also note the hole drilled in the sill as i want to give the repair a good internal coat of cavity wax
i then give the whole repair a small smear of good body filler and rub it back just to smooth it out then a few coats of stone guard to protect it
I have owned my welder for about 2 years and have only welded about 5 sills and 2 exhasts it cost me ÂŁ50,00 and have had no training so it shows any one can do it and save loads.
Tangoman
Re: sill repair on your drive
Postby Tangoman » Sat Jun 15, 2013 12:10 pm
Nicely done! :handgestures-thumbup:
Image Image
roadster1980
Postby roadster1980 » Sat Jun 15, 2013 5:41 pm
It is a job well done but I can't help but think that with the patch you have put in, from the second picture it looks like a fair bit of surface rust that goes a lot further that you can see sorry,
I can see this working for a mot for 12 months, we charge 75 for a patch for mot's
So unless you know someone with a welder you can borrow I can't see the point,
Like I said I'm not slating the work the final pic of it finished is fine it's just the during pics
td-05 turbo@.6bar 190.8hp
Build thread
viewtopic.php?f=35&t=1399
Postby flea » Sat Jun 15, 2013 5:47 pm
I agree with Steve (above) But fair play to your good effort :handgestures-thumbup: You need to be a bit unkind to the car first to get all the crap out :wink:
BaZa
Postby BaZa » Sat Feb 22, 2014 6:10 pm
Can this be done with an ARC welder?
Was thinking of buying a 2nd hand one and giving this a go.
Got charged a small fortune last year for some cill welding at MOT and this looks like something I could tackle I think.
ta
BaZ
Mk 1 1992 Black 1.6 with Silver Hard Top. Garaged needing alot of work (welding etc.)
Mk 2 2001 Red 1.8 with matching Hard Top
Mk 2.5 2002 Black 1.6 with Silver Hard Top
Postby flea » Sat Feb 22, 2014 6:21 pm
BaZa wrote:Can this be done with an ARC welder?
ta
BaZ
I had a go with a arc welder a few years back it just burned holes through the metal. Best to use a Mig :handgestures-thumbup:
Badknee
Postby Badknee » Sat Feb 22, 2014 6:37 pm
I used to love gas then went onto use MIG, now I use a body shop :laughing-rolling:
Paul & Angela.
'93 1.8 in Super Silver
Fully blinged up (thanks M-m)
Postby flea » Sat Feb 22, 2014 6:43 pm
Badknee wrote:I used to love gas then went onto use MIG, now I use a body shop :laughing-rolling:
:laughing-rolling: ........ :snooty:
Badknee
Postby Badknee » Sat Feb 22, 2014 7:29 pm
What? :whistle:
Paul & Angela.
BaZa
Postby BaZa » Tue Mar 11, 2014 10:54 pm
Thanks guys,
I'll look out for a mig then.
cheers,
BaZ
Pinky1984
Postby Pinky1984 » Wed Mar 12, 2014 10:12 am
1989 Eunos Roadster
Badknee
Postby Badknee » Thu Mar 13, 2014 8:44 pm
BaZa wrote:Thanks guys,
cheers,
BaZ
You will have to be quick, them migs fly very fast :wink: :lol:
Paul & Angela.
Return to “General Body shop”
