Pete has yet another flat battery problem Mk1>Mk 2.5
Pete is a real MX5/Roadster enthusiast and as such owns all version of the car. He's also incredibly unlucky with his cars which suffer from just about every ailment we have come across (and a few we haven't - yet). With your help we can keep all his cars on the road and the smile on his face so please come in and see if you can help.
THESE ARE COMMON AND GENUINE PROBLEMS WITH REAL ANSWERS - WELL WORTH A READ
Postby Mazda Mender » Mon Oct 15, 2012 8:09 pm
Pete got in his pride and joy this morning, turned the key and nothing. With the help of his wife they jump started the and off he went to work, a 20 mile drive from home. At 5.30 this evening on leaving work, the car is dead again, he is at a loss as to whats wrong as he thought that the 20 mile drive would have put some charge into the battery.
Can you help him
Doogledog
Re: Pete has yet another flat battery problem Mk1>Mk 2.5
Postby Doogledog » Tue Oct 16, 2012 9:32 pm
When Pete got back to his car, did the car turn over or did he just get that annoying click when there's absolutely nothing? Looks like it's the latter so sounds like the battery is not charging at all - has Pete checked his alternator?
Postby Mazda Mender » Tue Oct 16, 2012 9:46 pm
He has a gizmo in the roadster that shows him what charge is going from the alternator into the Battery and it is throwing out 14.5 volts, so the alternator is OK .
Doogledog
Postby Doogledog » Tue Oct 16, 2012 9:59 pm
So guessing that since the voltage is ok when the engine is running that the connections must all be ok too - I presume he's checked them?
Postby Mazda Mender » Tue Oct 16, 2012 10:06 pm
All connections are good :handgestures-thumbup:
Colin S
Postby Colin S » Tue Oct 16, 2012 10:09 pm
Assuming it has an OEM type Gel battery does it need to have a proper slow charge from a hi-tec charger such as a C-tek or optimate to bring it back up?
Racing Bronze Mk2 1.8iS
Postby Mazda Mender » Tue Oct 16, 2012 10:21 pm
Colin S wrote:Assuming it has an OEM type Gel battery does it need to have a proper slow charge from a hi-tec charger such as a C-tek or optimate to bring it back up?
Thanks Colin.
Peter bought himself a accumate smart trickle charger, left her on trickle charge to recondition the gel battery, and he has a smile on his face again.
Return to “Peter's Poorly Mx-5/Roadster problems”
