Pete's MK 2/2.5 heater blower is not working( no speeds)
He's back and this time with his MK 2/2.5 he as come to put the heater on as normal and as nothing, the speed control is doing jack, blower is not kicking in on any of the speed settings 1 to 4.
It is winter and it's cold, so he needs his heater to also keep the windscreen clean from fogging up as driving around withe the windows open at this time of year all the time is not an option. everything else works.
Can you help the fellow owners keep his toes warm
Re: Pete's MK 2/2.5 heater blower is not working( no speeds)
Has he looked at the fuses? What did he find?
Has the switch gone foopa, try another switch.
2nd Weston Park April 2017
Could be the heater resistor .
flea wrote:Has he looked at the fuses? What did he find?
He as checked all fuses and nothing is blown in the cab or engine bay
Speedy wrote:Has the switch gone foopa, try another switch.
Will pass that on and get it swapped and tried and get back to let you all know if that is the problem.
- nedski
- Serial Poster
Ford and Vauxhall 9 times out of ten it the rheostat/resistor. But high speed will always work as it bypasses the resistor.
Renaults often melt the wires up in the dash next to the motor.
Mx5's
Mx5's
Maybe just as simple as a wire or connector thats come adrift
Connections are all fine, he as chased everything back.
Mxmurray wrote:Could be the heater resistor .
He as tried that and it is fine, he has been told that if the resistor had failed or faulty it would bring on the fault of only working at full speed (number 4)
So...its a switch,a resistor a blower motor,wiring and fuses.
Switch has been checked.
Resistor ruled out as the motor doesn't blow at all.
Has the motor been checked?
Has any of the wiring suffered damage? Or is there a short in the system?
He said that he tried a new switch, still the same, he as tried the power to the motor and there is nothing.
Everything else is ok
On the plus side the weather as warmed up a bit
live wire from fuse box loose or dirty connection or even off?
earth wire from heater broken?
Is there something stuck in the blower fan preventing it from turning?
fujikun wrote:live wire from fuse box loose or dirty connection or even off?
All checked and all good.
GlennyGills wrote:Is there something stuck in the blower fan preventing it from turning?
He has tried another motor and no difference
