Hi there I was wondering if anyone could solve this problem. I recently purchas a Mazda MX5 MK1 that had been sat for 3 years. Being my first project I started by stripping the car and not working on the main problem that it did not run. After diagnosing that there is no spark I went and replaced the igniter, ECU and CAS to still find that there is no spark. I have also purchased a diagnostic tool to help diagnose; this let's me control the switch like fans and fuel pump however tells me these no fault and wont let me operate switch like clutch pedal or accelerator.
If anyone can help me with this it would be a massive help.
Many thanks
Brandon
Turns over but no spark
Re: Turns over but no spark
First off welcome..
If you are getting no fault codes then simply becomes a case of a process of illumination by swapping components...
So she is defo getting fuel ? So spark and air next..are the coil packs ok? HT leads and plugs?..also AFM.
Mazda Mender wrote:First off welcome..
I pulled the fuel line to the engine and it shot fuel everywhere, I have not take the injectors out yet, is that something worth doing? The car is definitely not getting spark I bought a tester for that and it confirms it. The HT leads show good ohms and the same with the coil pack.
Is there a list of things I should go thought to determine the problem with the spark ? As mention I replaced igniter, CAS sensor and ECU. Is there anything I'm not checking that could stop the spark sparking ?
Many thanks
Try a AFM.
Does she have a alarm system/immobilizer fitted?
I sometimes have trouble with the connector from loom to coil pack, and I've read other people have encountered this too. I'm new in terms of working on this car but it's common in other similar electronic connectors for the female terminals to open up. Worth a look?
Mazda Mender wrote:Does she have a alarm system/immobilizer fitted?
Users browsing this forum: No registered users and 17 guests
