Code 1 is either the coil or igniter....viewtopic.php?f=59&t=4893
93 Mk1 Starts then dies, fault 10
Re: 93 Mk1 Starts then dies, fault 10
- alexcruncha
- Just Run In
Thanks for pointing out that post.
Well since I tried changing almost everything except ignitor I did order one. It will arrive probably tomorrow. I will post the results. Failing that looks like the next logical step is to start checking wiring with a multimeter and look at the harness in closer detail. g0aku did a great job to hunt down his wiring issue.
- alexcruncha
- Just Run In
Mazda Mender wrote:Code 1 is either the coil or igniter....http://www.mazdamenders.net/forum/viewt ... =59&t=4893
Well time to celebrate. Changed the ignitor and shes running again.
Now I have lifter noise that wasnt there before (used to run smooth as ever with not even any startup clatter). I assume the lifter type noise is because I replaced the CAS and now the ignition timing is not set. I have a timing lamp so will do that on Saturday and report on my progress.
- alexcruncha
- Just Run In
I just found time to take her out for a run. Lifter noise disappeared after the engine was warmed up so must have been not starting the engine for some time let all the thin 0w40 oil to end up in the sump. Ignition timing must be close as its running well. Will check on that tomorrow but I'm now done.
Thanks everyone for all the help and support to keep going and help me fix this issue! I've just booked the MOT for next Tuesday (2 days before expiry).
Thats what menders is here for, you have a problem, the guys on here offer advice and suggestions, you solve the issue and that in turn adds to the wealth of knowledge on Mazda Menders for us all to share.
Great stuff ...get out and enjoy her now buddy..
