Cooling and Coolant Issues.
BenF
Re: Cooling and Coolant Issues.
Postby BenF » Fri Aug 15, 2014 7:20 am
alligatorlizard wrote:I had what sound like the same symptoms for ages with my 1992 import - shortly after getting it I had various cooling problems that led to most hoses replaced, new rad and new water pump/thermostat - so after this I knew the cooling system itself was in pretty good shape, but nonetheless, the needle always climbed a bit (sometimes just slightly right of centre, sometimes almost halfway towards the "H", depending on weather) when stuck in traffic or at lights. Was like this for maybe two years, didn't seem to be doing any damage, and besides there was nothing I could do because none of the mechanics I took it to could figure out why it wasn't holding it's temperature better - and to be fair, the cause was hard to spot, because the fan did work, only it clearly wasn't working at full capacity... Recently it died completely, and since replacing it, the needle's never moved from it's usual position just left of centre. So after all the things I tried (and many posts on MX5OC etc!) it turned out to be just a weak fan.
Anyway, if yours isn't turning at all, there's no doubt that's where your problem lies! I'd say it's an easy fix too, compared to any problems with the actual coolant system.
this is a good shout. Have also seen poor wiring do the same - and remember mk.1's are well into 'classic car rules' now :handgestures-thumbup:
SteveSwain
Postby SteveSwain » Fri May 18, 2018 11:54 am
Can you explain where the coolant temp sensor relay is please. I have fitted three coolant switches in the last 18 months which cures the fan coming on when they are new but the last one which worked fine after fitting is now playing up after only two weeks so I am wondering if it is the relay? Mk1 Eunos ‘89 1.6.
Postby Mazda Mender » Sat May 19, 2018 10:24 pm
What condition is the rad in....new? Old?...is the plug to the housing switch ok wire/ connection .
Users browsing this forum: No registered users and 39 guests
