Headlight Cleaning
scunninghamk
Headlight Cleaning
Postby scunninghamk » Mon Dec 18, 2017 8:32 pm
I’m trying to shine these up a bit. They are a bit ‘foggy’ and though I’ve tried a couple of products they’re not as bright as I want yet. Any ideas?
Re: Headlight Cleaning
Postby Mazda Mender » Mon Dec 18, 2017 10:49 pm
Pictures are needed.
V6 Power Junkie
Postby V6 Power Junkie » Fri Dec 22, 2017 9:56 am
https://youtu.be/UEJbKLZ7RmM
Sent from my LG-H815 using Tapatalk
Postby blackyb » Sun Dec 24, 2017 4:53 pm
I have seen this done using 2000 grit wet and dry with half decent results, but for a quick fix I use G2 rubbing compound, not as brutal as wet n dry but you might have to do it again after a couple of years.
2003 1.8 SVT Sport (Why did I sell it!!!!)
Postby Mazda Mender » Sun Dec 24, 2017 10:14 pm
T-cut...
scunninghamk
Postby scunninghamk » Sun Dec 24, 2017 11:09 pm
I took some pictures Image
Postby Mazda Mender » Mon Dec 25, 2017 11:20 am
T-cut ;0)
madmart100
Postby madmart100 » Thu Mar 08, 2018 5:09 pm
toothpaste (with the little bits in it) works. :shock: And Autosol chrome cleaner. check out videos on youtube
robabarker
Postby robabarker » Fri Mar 09, 2018 3:05 pm
It's always best (though not necessarily the cheapest) to start with the least aggressive method and work your way up.
I went with a T-Cut headlight restoration kit, which did the job well. The compound is thicker and more abrasive than normal T-Cut, more like a paste, which helps to reduce mess, and it included a sealant too, which should help prevent future hazing from UV damage... at least in theory!
MM-tinkered '98 Roadster RS
Users browsing this forum: No registered users and 5 guests
