A while ago now I decided that the dash top on our MKI was looking a little bit tatty, now I am not an upholster by any means but thought I would give it a try.
I ordered from ebay an automotive grade leather hide that was already perforated. I didnt want to take the dash out so I made a template from thick brown paper and set to work with a stanley knife and some sharp scissors.
It wasn't an easy job, but after a good few hours and plenty of cutting and trimming I am pleased with the result.
So, if your dash is looking past its best then give it a go, all you need is courage, a knife, some brown paper and some impact adhesive.
I had already fitted a leather cowl cover. The vents were the biggest problem so I ordered the chrome covers and the side vent chrome insets I already had from the porn site.
This is the result.
By buying a hide there was more than enough leather to tackle other areas of the interior, so I decided to do the tops of the door cards.
Covering a MKI dash top in leather
- Turbo Charged
Re: Covering a MKI dash top in leather
Very nice it looks too
Cracking job! You could cover that steering wheel too if you`ve got any left
DAVE
THAT LOOKS COMPLETELY AWESOME!!!
have you got the ebay link for the seller, I fancy doing something like that, have you cut around the front vents ect?
- Turbo Charged
Thanks, it could be better, but first attempt and that...................
I think this is the seller, although this link shows it in blue, if you contact them they may have black available.
http://www.ebay.co.uk/itm/Full-Leather- ... 4160804c86
I made a rough template from brown paper, its pretty awkward and easier if you take the cowl off and possibly the wheel. I deliberately overcut so that I could trim it a piece at a time while in the car. Once I had the leather cut out I then positioned it in the car and then marked where the vents needed to be cut out, it was then a case of keep taking it to the cutting board and back again, and then the final cuts were made in place, but be careful, leather cuts easily sometimes, and when you least expect it.
To be honest the way I looked at it was that if I messed up I had lost ÂŁ60 and some time, just take your time, measure twice - cut once is the saying. The side are tough and need accurate cutting with the leather in place, pull out the vent covers and they will probably need some cutting underneath to get them back in, mine are held in place with glue.
The screen vents are also tough as I couldn't work out a way of getting the leather to look neat, thats why I bought the chrome vent covers, these have some bits of cut up cable tie glued to the base of them to give them some extra height and then glued to the plastic bars inside the vents.
Good luck, its very fiddly but very, very satisfying once you have done it. But dont glue until you are happy with it, to keep in place for cutting and tidying up I pushed it between the dash and the crash panel with a plastic scraper.
Neat, tidy, well executed and well finished.
Nice work. It's seeing stuff like this done that inspires others confidence
Regards, Hammy.
Great job there looks wicked!
More than impressed !!!!!
Yes, that is very nice. I like the fact that you have used the leather with 'holes' in it - makes all the difference. I have seen a couple of covered dashes before and really didn't like the effect but this one works.
Niall
1997 1.8i Roadster in Black
1998 1.8i S MX-5 in Silver
- Under restoration
- Under restoration
It looks even better in the flesh
Hats off, sir. That looks brilliant.
Ricolas
Beckenham, Kent
Beckenham, Kent
