Mx5 1.8 euphonic oem fog lights
njonesn
Re: Mx5 1.8 euphonic oem fog lights
Postby njonesn » Tue Nov 27, 2018 9:30 pm
Mazda Mender wrote:Try the other side of the fuse box, there is another flap.
Took another look today, there is no flap on the other side. Did a bit or research and I think there is on the MK1. The 10AE is MK2 and on this the live is wired via a push clip into the base of the fuse box. Seemingly no way to tap into that without cutting the wire as its a proper clip, not bolted terminal.
10th Anniversary Edition (1999 NB)
Postby Mazda Mender » Tue Nov 27, 2018 11:38 pm
You can tap into one of the lives coming from the fuse box underneath bud
njonesn
Postby njonesn » Tue Nov 27, 2018 11:53 pm
Thanks, that is the current plan. Appreciate the guidance. Ta.
Postby Mazda Mender » Wed Nov 28, 2018 12:37 am
Are you fitting these to a Mk2 or 2.5 as i see you have a 10th edition...
njonesn
Postby njonesn » Wed Nov 28, 2018 1:19 am
1999 MK2
Postby Mazda Mender » Wed Nov 28, 2018 7:12 am
Ok , I have a VS 1998 here,which basically the same model with a different interior i'll find you which wire to tap into of her.
njonesn
Postby njonesn » Wed Nov 28, 2018 8:27 am
Cheers. Currently I have been advised to take a feed from the TNS relay, either input or output as the fogs should only function when the side lights are on so this should be good for both the coil and switched pins on the relay that came with the Ring kit.
Postby Mazda Mender » Wed Nov 28, 2018 8:59 am
Yes.... i have seen, DO NOT use a permanent live feed, needs to be switched ignition live or from the lighting circuit.
Return to “MK2”
