- 100_3036.jpg (183.17 KiB) Viewed 8886 times
- 100_3037.jpg (299.46 KiB) Viewed 8886 times
Chadz.
blackyb wrote:That's good to know, is it the same procedure on a Mk1??
chadz wrote:Thats great for preparing the old filter for removal. What I need to know is which pins in the diagnostic box are to be bridged to reboot the fuel pump! Or are you suggesting that this is not required and that simply making the broken connection does the biz and cranking alone will repressurise the system?
Chadz
chadz wrote:High - Just had a look at a video on u-tube 'Mazda Miata fan' episode 7 - fuel filter replacement. It takes you through the whole procedure. I did notice that the lid of the diagnostic box on the car being worked on had a sticker showing what all the pin outs were. This is not present on my car and I am reluctant to put the bridging wire in just anywhere.
The other slight difference to your method Wayne is that he disconnected the fuel pump connector under the removable panel underneath the steering column. Am I right in assuming that you took out the fuse to the fuel pump?
Chadz
