Cam belt/oil change?
Hi all, I'm having the cam belt/waterpump and whatever else needed done in a couple of weeks, and maybe the 0 ring, does she need an oil change at the same time? I had a change 500 miles or so ago with fully synthetic but I am lead to believe I shouldn't have asked for that anyway. If thats true whats the best oil to get them to use (if she needs it)? Cheers guys, Mick.
Re: Cam belt/oil change?
For your Mk1 Wayne usually recommends semi-synth but fully synth is fine. Certainly not worth changing it over now.
For the work you are having done there should be no need to replace the oil.
- BenF
- Epic Poster
What he ^ said, but dependent on what the 'whatever else is needed' adds up to. If thats a sump gasket, then it would etc.
BRG MKI '90 F-SPEC
'ad victorem ire spolia'
my build (condensed)
Sponsor - PROTECH SHOCKS
Supplier - AUTOLINK
Supplier - AUTOLINK
Thanks. Should I use the synthetic next time now I've started or whats the best option?
You can use whatever you like. Synth, semi & mineral oils are all mineral based anyway so can mix without a problem.
Personally I prefer a good full synth in Mk1s but Wayne disagrees with me
- BenF
- Epic Poster
Depends on how often you change it buddy - a good full synth I'd run to 10k or two seasons. Semi to 6-7, mineral 3-4k.
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
- nedski
- Serial Poster
^ +1 what Ben said
- binarypunk
Get whichever is in 'the sale' at eurocarparts at the time... Last month is was semi for £12/5ltr, this month it is full synth for £13...
The most important thing is to replace it and the filter regularly, on schedule.
Lazza wrote:You can use whatever you like. Synth, semi & mineral oils are all mineral based anyway so can mix without a problem.
The car in standard form was designed to run on semi synth, boosted is a different story which i recommend fully no matter which version, in standared form i would recommend a engine flush ,more so on the MK 1's to keep those tappets nice and clean so you get no build up of used old tacky sticky oil makeing them noisey.
Wayne wrote:Lazza wrote:You can use whatever you like. Synth, semi & mineral oils are all mineral based anyway so can mix without a problem.
We do actually agree but in different ways. You prefer semi and an oil flush whereas I prefer full synth which should mean no need for oil flush. I just don't like oil flushes on older engines unless they really need it.
Lazza wrote:Wayne wrote:Lazza wrote:You can use whatever you like. Synth, semi & mineral oils are all mineral based anyway so can mix without a problem.
There is no need to do it at every oil change, but when you get one that has not been done for 3 years(oil change) then there is a need for it to be done, once on top of it, then every other service is good like anyifreeze and so on.
- BenF
- Epic Poster
Wayne wrote: ...when you get one that has not been done for 3 years(oil change)
That means YOU, Ian
BRG MKI '90 F-SPEC
Supplier - AUTOLINK
Supplier - AUTOLINK
BenF wrote:Wayne wrote: ...when you get one that has not been done for 3 years(oil change)
That means YOU, Ian
My Oil was changed every 1000 miles whether I wanted to or not
2nd Weston Park April 2017
Confused.com here, My old 5 (65000) only does about 1000 miles a year, maybe double that this year if I get her out to Norway. Summer before last had a full service at Sulston hills then about a 1000 miles ago had all the oils changed at MX5parts. So surely she wont need an engine flush or doesnt that have anything to do with changing oil regularly? I just assumed regular changing flushes it. When should I get an oil change next? And should I get a flush? Does oil deteriate when it sits for a year or so with little use? I thought the dearest would be the best. God I have a lot to learn.......cheers guys.
- binarypunk
Oils (and most fluids) do indeed deteriorate over time. The service interval on your car is 6k or 1 year whichever comes first. Stick to that and you're fine....even if it has done 1 mile, you should still do the service every 12 months.
If you have HLA rattle (a second or so tappety noise on startup from cold) then you might benefit from a flush, but otherwise and if you change the oil regularly, there is no need.
