My car has developed a squeaking front suspension. Whenever I turn quickly or go over bumpy roads, I get a quite noisy high ppitched squeak. I tried silicone spraying the suspension rubbers one by one, but ended up spraying everything. Still it squeaks.
Squeaky front suspension
Re: Squeaky front suspension
Is she sitting on billies by any chance?
My Mk1 squeaks from the rear when at high speed going over rough surfaces. It's not yet got annoying enough for me to look into it any further but I assumed it was a spring. My car is sitting on Rokkors so definitely not Bilsteins.
Niall
1997 1.8i Roadster in Black
1998 1.8i S MX-5 in Silver
- Under restoration
- Under restoration
The billies have a trait in that with the angle they sit at, the damper bush over time squashes and pushes out resulting in a squeak because of the pressure, the only cure is the replace the bushes, the dampers are very hard wearing and go on for years, no amount of silicon lube will stop the squeak.
The squeak on the racelands will more than likely be the bottom spring, or the roadster trying to tell you that she wants proper suspension, i know they do there job to a certain extent and are cheap, but they are cheap and i really do not like raceland damperss , i have replaced so many sets over the years,sorry Paggers, nothing personal aimed to yourself buddy.
I don't take it personally, they were on the car when I bought it and I don't like them either. If I had the money I would put MeisterR suspension on both my cars but I don't have the money (not at the moment anyway) so I live with what I've got.
Niall
- Under restoration
- Under restoration
mazda-mender wrote:Is she sitting on billies by any chance?
Had a quick look and the shocks are Excel G-Gas. Don't know how old they are, but the rubber dust covers within the springs have all but disintegrated.
Have you checked the bushes on everything? and which silicon lube did you use.
As paggers as said it could be the springs coils rubbing .
mazda-mender wrote:The billies have a trait in that with the angle they sit at, the damper bush over time squashes and pushes out resulting in a squeak because of the pressure, the only cure is the replace the bushes, the dampers are very hard wearing and go on for years, no amount of silicon lube will stop the squeak.
I've had Racelands on my 5 for the past 3 years now, and have noticed they get worse after its rained and is damp, they've been quiet during this recent dry patch. All this leads me to believe that the moveable bump stops that they have are the cause of the squeak!
mazda-mender wrote:Have you checked the bushes on everything? and which silicon lube did you use.
I took your general advice M-m and bought Halfords spray.
How would I go about stopping a noise from the springs.
Oil or/and grease on the springs, silicon everywhere else, silicon is geared for rubber and plastic.
