Judith was mad enough to throw the key at me again, this time for a service, all oils, water pump and cam belt and all seals, full brake service and strip and underseal sort a section in the engine bay and basically refresh...
So i hit this in 6 stages for her, and this is a ref for her incase in the future the keys are handed over to someone new?
The MX5 as 30'000 on her and is rot free, (pics to follow) this was well looked after by her late husband Geoff and a man after my own heart with how he had been looking after Her and was a credit to him.
Stage 1 was was strip down the left and side to eradicate some surface rust that was trying to take a bait...
Judiths MK 2.5 1.6
Judiths MK 2.5 1.6
- 20180526_114334.jpg (468.35 KiB) Viewed 5556 times
- 20180526_114341.jpg (487.19 KiB) Viewed 5556 times
- 20180526_114357.jpg (480.73 KiB) Viewed 5556 times
- 20180526_114412.jpg (492.45 KiB) Viewed 5556 times
- 20180526_114418.jpg (494.03 KiB) Viewed 5556 times
- 20180526_151217.jpg (627.52 KiB) Viewed 5556 times
- 20180526_151225.jpg (665.57 KiB) Viewed 5556 times
- 20180526_151229.jpg (541.15 KiB) Viewed 5556 times
- 20180526_151254.jpg (536.1 KiB) Viewed 5556 times
- 20180526_151306.jpg (488.43 KiB) Viewed 5556 times
- 20180526_151311.jpg (505.8 KiB) Viewed 5556 times
- 20180526_180718.jpg (498.97 KiB) Viewed 5556 times
- 20180526_180724.jpg (564.93 KiB) Viewed 5556 times
- 20180526_180732.jpg (553.07 KiB) Viewed 5556 times
- 20180526_184309.jpg (561.76 KiB) Viewed 5556 times
- 20180526_184313.jpg (492.55 KiB) Viewed 5556 times
- 20180526_184318.jpg (474.29 KiB) Viewed 5556 times
- 20180527_111804.jpg (636.07 KiB) Viewed 5556 times
- 20180527_171012.jpg (709.46 KiB) Viewed 5556 times
- 20180527_171022.jpg (727.69 KiB) Viewed 5556 times
Re: Judiths MK 2.5 1.6
Still with stage one because i noticed it.....
- 20180526_180701.jpg (674.99 KiB) Viewed 5555 times
- 20180526_180709.jpg (633.44 KiB) Viewed 5555 times
- 20180526_183009.jpg (492.98 KiB) Viewed 5555 times
- 20180526_183013.jpg (462.98 KiB) Viewed 5555 times
- 20180526_184325.jpg (459.96 KiB) Viewed 5555 times
- 20180526_184330.jpg (477.9 KiB) Viewed 5555 times
- 20180526_185740.jpg (629.99 KiB) Viewed 5555 times
- 20180526_185749.jpg (645.51 KiB) Viewed 5555 times
Stange two :- was service time, gearbox oil,diff oil, engine oil,oil filter, air filter, spark plugs, Aux belts....
water pump, alder ,tensioner and spring, cam seals, crank seal, rocker seal, timing belt ,5 yr collant....
- 20170408_115230.jpg (581.25 KiB) Viewed 5458 times
- 20170408_114646.jpg (483.91 KiB) Viewed 5458 times
- 20180524_205117.jpg (562.61 KiB) Viewed 5555 times
- 20180524_205122.jpg (583.34 KiB) Viewed 5555 times
- 20180524_205132.jpg (586.44 KiB) Viewed 5555 times
- 20180524_205138.jpg (607.35 KiB) Viewed 5555 times
- 20180524_211149.jpg (578.75 KiB) Viewed 5555 times
- 20180524_211207.jpg (667.91 KiB) Viewed 5555 times
- 20180526_112624.jpg (568.05 KiB) Viewed 5555 times
- 20180526_112633.jpg (638 KiB) Viewed 5555 times
- 20180526_112828.jpg (536.22 KiB) Viewed 5555 times
- 20180526_123534.jpg (526.17 KiB) Viewed 5555 times
- 20180526_123541.jpg (654.14 KiB) Viewed 5555 times
- 20180526_123556.jpg (576.07 KiB) Viewed 5555 times
- 20180526_123601.jpg (618.8 KiB) Viewed 5555 times
- 20180526_131804.jpg (569.23 KiB) Viewed 5555 times
- 20180526_131818.jpg (596.9 KiB) Viewed 5555 times
- 20180526_131828.jpg (586.36 KiB) Viewed 5555 times
- 20180526_131836.jpg (606.03 KiB) Viewed 5555 times
- 20180526_132154.jpg (649.9 KiB) Viewed 5555 times
- 20180526_132208.jpg (559.07 KiB) Viewed 5555 times
- 20180526_132212.jpg (695.69 KiB) Viewed 5555 times
- 20180526_133456.jpg (608.31 KiB) Viewed 5555 times
- 20180526_133502.jpg (595.21 KiB) Viewed 5555 times
- 20180526_141031.jpg (598.31 KiB) Viewed 5555 times
- 20180526_141037.jpg (536.99 KiB) Viewed 5555 times
- 20180526_141041.jpg (599.22 KiB) Viewed 5555 times
- 20180526_151433.jpg (659.34 KiB) Viewed 5555 times
- 20180526_151618.jpg (637.49 KiB) Viewed 5555 times
- 20180526_151624.jpg (657.9 KiB) Viewed 5555 times
Stange three :- was the brake service, the only thing that was missing was the anti rattle springs off the front pads and a good clean up,de surface rust ,file back where needed, and lube added metal to metal contact and protection ...copper grease, rubber sliders...red rubber grease...all freash brake fluid fully balanced and working better than she was even at the factory...
- 20180527_132818.jpg (747.89 KiB) Viewed 5555 times
- 20180527_132831.jpg (572.42 KiB) Viewed 5555 times
- 20180527_135314.jpg (614.97 KiB) Viewed 5555 times
- 20180527_135320.jpg (584 KiB) Viewed 5555 times
- 20180527_170741.jpg (637.59 KiB) Viewed 5555 times
- 20180527_170755.jpg (641.92 KiB) Viewed 5555 times
Stage 4:- was strip the Mx down and wrap and prep up ready for undersealing her.....
- 20180602_190820.jpg (618.89 KiB) Viewed 5555 times
- 20180602_190811.jpg (627.66 KiB) Viewed 5555 times
- 20180602_190802.jpg (645.99 KiB) Viewed 5555 times
- 20180602_190745.jpg (566.96 KiB) Viewed 5555 times
- 20180602_190741.jpg (582.31 KiB) Viewed 5555 times
- 20180602_190730.jpg (615.62 KiB) Viewed 5555 times
- 20180531_185902.jpg (553.54 KiB) Viewed 5555 times
- 20180531_184202.jpg (577.67 KiB) Viewed 5555 times
- 20180531_184034.jpg (444.88 KiB) Viewed 5555 times
- 20180531_184030.jpg (445.12 KiB) Viewed 5555 times
- 20180531_184025.jpg (525.21 KiB) Viewed 5555 times
- 20180531_184018.jpg (481.93 KiB) Viewed 5555 times
- 20180531_184012.jpg (422.51 KiB) Viewed 5555 times
- 20180531_184007.jpg (450.95 KiB) Viewed 5555 times
- 20180531_183944.jpg (524.39 KiB) Viewed 5555 times
- 20180531_183940.jpg (533.08 KiB) Viewed 5555 times
- 20180531_183935.jpg (623.01 KiB) Viewed 5555 times
- 20180531_183930.jpg (600.55 KiB) Viewed 5555 times
- 20180531_183924.jpg (554.79 KiB) Viewed 5555 times
- 20180531_183919.jpg (552.34 KiB) Viewed 5555 times
- 20180531_183910.jpg (630.92 KiB) Viewed 5555 times
- 20180531_183905.jpg (607.87 KiB) Viewed 5555 times
- 20180531_183900.jpg (426.78 KiB) Viewed 5555 times
- 20180531_183856.jpg (512.79 KiB) Viewed 5555 times
- 20180531_183852.jpg (577.93 KiB) Viewed 5555 times
- 20180531_183845.jpg (510.45 KiB) Viewed 5555 times
- 20180531_183836.jpg (631.89 KiB) Viewed 5555 times
- 20180531_183830.jpg (576.06 KiB) Viewed 5555 times
- 20180531_183825.jpg (627.38 KiB) Viewed 5555 times
- 20180531_183820.jpg (497.63 KiB) Viewed 5555 times
- 20180531_183816.jpg (617.64 KiB) Viewed 5555 times
- 20180531_183809.jpg (493.73 KiB) Viewed 5555 times
- 20180531_183755.jpg (487.28 KiB) Viewed 5555 times
- 20180531_183749.jpg (426.06 KiB) Viewed 5555 times
- 20180531_183738.jpg (460.58 KiB) Viewed 5555 times
- 20180531_183727.jpg (496.73 KiB) Viewed 5555 times
- 20180531_183720.jpg (666.72 KiB) Viewed 5555 times
- 20180531_183715.jpg (651.8 KiB) Viewed 5555 times
- 20180531_183708.jpg (615.9 KiB) Viewed 5555 times
- 20180531_183702.jpg (491.46 KiB) Viewed 5555 times
- 20180531_183653.jpg (556.15 KiB) Viewed 5555 times
- 20180531_183639.jpg (543.99 KiB) Viewed 5555 times
- 20180531_183626.jpg (373.98 KiB) Viewed 5555 times
- 20180527_170942.jpg (584.7 KiB) Viewed 5555 times
- 20180527_170934.jpg (580.33 KiB) Viewed 5555 times
- 20180527_170921.jpg (515.91 KiB) Viewed 5555 times
- 20180527_170857.jpg (569.6 KiB) Viewed 5555 times
- 20180527_170852.jpg (569.82 KiB) Viewed 5555 times
- 20180527_170847.jpg (601.35 KiB) Viewed 5555 times
- 20180527_170837.jpg (439.33 KiB) Viewed 5555 times
- 20180527_170833.jpg (495.63 KiB) Viewed 5555 times
- 20180527_170826.jpg (598.22 KiB) Viewed 5555 times
- 20180527_170735.jpg (596.7 KiB) Viewed 5555 times
- 20180527_170731.jpg (634.48 KiB) Viewed 5555 times
- 20180527_170725.jpg (595.41 KiB) Viewed 5555 times
- 20180527_170703.jpg (559.97 KiB) Viewed 5555 times
- 20180527_170502.jpg (731.73 KiB) Viewed 5555 times
- 20180527_170644.jpg (678.1 KiB) Viewed 5555 times
- 20180527_170639.jpg (798.86 KiB) Viewed 5555 times
Rust is terminal..... i guess it is time to write her off...
- 20180602_202805.jpg (506.5 KiB) Viewed 5555 times
- 20180602_202810.jpg (511.3 KiB) Viewed 5555 times
- 20180602_202817.jpg (474.5 KiB) Viewed 5555 times
- 20180602_202828.jpg (483.19 KiB) Viewed 5555 times
- 20180602_202838.jpg (513.6 KiB) Viewed 5555 times
- 20180602_202856.jpg (535.16 KiB) Viewed 5555 times
- 20180602_202901.jpg (467.55 KiB) Viewed 5555 times
- 20180602_202910(0).jpg (471.09 KiB) Viewed 5555 times
- 20180602_202910.jpg (479.48 KiB) Viewed 5555 times
- 20180602_202916.jpg (442.05 KiB) Viewed 5555 times
- 20180602_202935.jpg (443 KiB) Viewed 5555 times
- 20180602_202940.jpg (406.9 KiB) Viewed 5555 times
- 20180602_203012.jpg (388.53 KiB) Viewed 5555 times
- 20180602_203017.jpg (385.62 KiB) Viewed 5555 times
- 20180602_203027.jpg (484.3 KiB) Viewed 5555 times
- 20180602_203033.jpg (493.53 KiB) Viewed 5555 times
- 20180602_203039.jpg (427.73 KiB) Viewed 5555 times
- 20180602_203048.jpg (396.68 KiB) Viewed 5555 times
- 20180602_203110.jpg (499 KiB) Viewed 5555 times
- 20180602_203123.jpg (484.45 KiB) Viewed 5555 times
- 20180602_203137.jpg (386.37 KiB) Viewed 5555 times
- 20180602_203143.jpg (485.48 KiB) Viewed 5555 times
- 20180602_203150.jpg (486.3 KiB) Viewed 5555 times
- 20180602_203217.jpg (580.8 KiB) Viewed 5555 times
- 20180602_203225.jpg (595.64 KiB) Viewed 5555 times
- 20180602_203234.jpg (537.77 KiB) Viewed 5555 times
- 20180602_203240.jpg (539.54 KiB) Viewed 5555 times
- 20180602_203302.jpg (421.1 KiB) Viewed 5555 times
- 20180602_203307.jpg (362.37 KiB) Viewed 5555 times
- 20180602_203314.jpg (412.03 KiB) Viewed 5555 times
- 20180602_203323.jpg (359.08 KiB) Viewed 5555 times
- 20180602_203334.jpg (365.78 KiB) Viewed 5555 times
- 20180602_203340.jpg (351.04 KiB) Viewed 5555 times
- 20180602_203348.jpg (419.41 KiB) Viewed 5555 times
- 20180602_203353.jpg (432.5 KiB) Viewed 5555 times
- 20180602_203358.jpg (378.66 KiB) Viewed 5555 times
- 20180602_203421.jpg (494 KiB) Viewed 5555 times
- 20180602_203426.jpg (509.6 KiB) Viewed 5555 times
- 20180602_203431.jpg (531.75 KiB) Viewed 5555 times
- 20180602_203438.jpg (512.56 KiB) Viewed 5555 times
- 20180602_203444.jpg (459.74 KiB) Viewed 5555 times
- 20180602_203456.jpg (509.98 KiB) Viewed 5555 times
- 20180602_203508.jpg (535.14 KiB) Viewed 5555 times
- 20180602_203513.jpg (521.15 KiB) Viewed 5555 times
- 20180602_203519.jpg (506.02 KiB) Viewed 5555 times
- 20180602_203524.jpg (499.67 KiB) Viewed 5555 times
- 20180602_203539.jpg (457.38 KiB) Viewed 5555 times
- 20180602_203545.jpg (543.58 KiB) Viewed 5555 times
- 20180602_203633.jpg (543.37 KiB) Viewed 5555 times
- 20180602_203638.jpg (518.8 KiB) Viewed 5555 times
- 20180602_203644.jpg (494.85 KiB) Viewed 5555 times
- 20180602_204933.jpg (606.81 KiB) Viewed 5555 times
- 20180602_204941.jpg (547.64 KiB) Viewed 5555 times
- 20180602_204945.jpg (558.78 KiB) Viewed 5555 times
- 20180602_204955.jpg (562.8 KiB) Viewed 5555 times
- 20180602_205001.jpg (540.41 KiB) Viewed 5555 times
- 20180602_205013.jpg (458.33 KiB) Viewed 5555 times
- 20180602_205024.jpg (460.35 KiB) Viewed 5555 times
- 20180602_205029.jpg (492.13 KiB) Viewed 5555 times
- 20180602_205048.jpg (578.43 KiB) Viewed 5555 times
- 20180602_205055.jpg (489.7 KiB) Viewed 5555 times
- 20180602_205107.jpg (513.3 KiB) Viewed 5555 times
Stage 5 :-All made good and undersealed.....
- 20180603_155101.jpg (602.74 KiB) Viewed 5553 times
- 20180603_155109.jpg (636.76 KiB) Viewed 5553 times
- 20180603_155114.jpg (594.39 KiB) Viewed 5553 times
- 20180603_155121.jpg (576.53 KiB) Viewed 5553 times
- 20180603_155127.jpg (545.4 KiB) Viewed 5553 times
- 20180603_155134.jpg (502.98 KiB) Viewed 5553 times
- 20180603_155143.jpg (588.58 KiB) Viewed 5553 times
- 20180603_155150.jpg (530.56 KiB) Viewed 5553 times
- 20180603_155201.jpg (657.32 KiB) Viewed 5553 times
- 20180603_155207.jpg (685.08 KiB) Viewed 5553 times
- 20180603_155212.jpg (620.13 KiB) Viewed 5553 times
- 20180603_155217.jpg (658.09 KiB) Viewed 5553 times
- 20180603_155228.jpg (696.47 KiB) Viewed 5553 times
- 20180603_155232.jpg (687.31 KiB) Viewed 5553 times
- 20180603_155239.jpg (669.57 KiB) Viewed 5553 times
- 20180603_155244.jpg (676.16 KiB) Viewed 5553 times
- 20180603_155251.jpg (578.84 KiB) Viewed 5553 times
- 20180603_155302.jpg (669.18 KiB) Viewed 5553 times
- 20180603_155311.jpg (641.1 KiB) Viewed 5553 times
- 20180603_155316.jpg (586.69 KiB) Viewed 5553 times
- 20180603_155323.jpg (527.28 KiB) Viewed 5553 times
- 20180603_155329.jpg (506.52 KiB) Viewed 5553 times
- 20180603_155338.jpg (564.81 KiB) Viewed 5553 times
- 20180603_155354.jpg (492.22 KiB) Viewed 5553 times
- 20180603_155401.jpg (606.23 KiB) Viewed 5553 times
- 20180603_155407.jpg (573.13 KiB) Viewed 5553 times
- 20180603_155416.jpg (580.53 KiB) Viewed 5553 times
- 20180603_155423.jpg (568.65 KiB) Viewed 5553 times
- 20180603_155428.jpg (576.25 KiB) Viewed 5553 times
- 20180603_155448.jpg (630.55 KiB) Viewed 5553 times
- 20180603_155454.jpg (628 KiB) Viewed 5553 times
- 20180603_155539.jpg (320.99 KiB) Viewed 5553 times
- 20180603_155553.jpg (419.72 KiB) Viewed 5553 times
- 20180603_155609.jpg (418.78 KiB) Viewed 5553 times
- 20180603_155623.jpg (377.64 KiB) Viewed 5553 times
- 20180603_155628.jpg (357.14 KiB) Viewed 5553 times
- 20180603_155637.jpg (389.02 KiB) Viewed 5553 times
- 20180603_155647.jpg (481.06 KiB) Viewed 5553 times
Stage 6 put her all back together with lashing of copper slip for the haters of preventive medicine.....
- 20180604_214613.jpg (615.04 KiB) Viewed 5459 times
- 20180604_214623.jpg (611.69 KiB) Viewed 5459 times
- 20180604_214636.jpg (643.36 KiB) Viewed 5459 times
- 20180604_214644.jpg (612.1 KiB) Viewed 5459 times
- 20180604_214655.jpg (742.54 KiB) Viewed 5459 times
- 20180604_214704.jpg (736.22 KiB) Viewed 5459 times
- 20180604_214711.jpg (714.55 KiB) Viewed 5459 times
- 20180604_214723.jpg (733.46 KiB) Viewed 5459 times
- 20180604_214731.jpg (663.92 KiB) Viewed 5459 times
- 20180604_214744.jpg (686.22 KiB) Viewed 5459 times
- 20180604_214807.jpg (673.33 KiB) Viewed 5459 times
And just for Ref for proof this is the Mx in question....
- 20180524_190742.jpg (611.88 KiB) Viewed 5459 times
- 20180524_190736.jpg (698.77 KiB) Viewed 5459 times
- 20180524_185430(0).jpg (492.99 KiB) Viewed 5459 times
- 20180524_185346.jpg (492.48 KiB) Viewed 5459 times
- 20180524_185254.jpg (384.79 KiB) Viewed 5459 times
- 20180524_185207.jpg (475.01 KiB) Viewed 5459 times
- 20180524_185158.jpg (472.15 KiB) Viewed 5459 times
- 20180524_185147.jpg (582.08 KiB) Viewed 5459 times
- 20180524_185141.jpg (597.54 KiB) Viewed 5459 times
Users browsing this forum: No registered users and 19 guests
