Mk 2 blue VS 1.8 import project...wayne mansion,08
Re: Mk 2 blue VS 1.8 import project...wayne mansion
I noticed a little bit of a bubble on the drivers front wing where it meets the front nose cone, on further inspection the wing had been a repair/replacement at some point and not a good one as it was rotten unlike the passenger side was was all good.
So lucky for me (thanks be to the Mr Fleming ) i had a very very good one in the body panel shed, so after a good clean and over kill of paint for protection on the back(which will also be undersealed to) i also sprayed all the leading edges in 12k as the wing is silver
So off came the one that arrived with her and the new one on....
Under bonnet prototype test lights fitted from Jass performance which are designed to help with that emergency when dark for checking screen wash,oil etc etc or forbid when broken down....the angle is perfect to light up the whole of the engine bay, discrete as in you really need to look to see them, they are on a on and off switch so only lit when needed and with them being LED's are low on burning wattage, very happy with them...
Vid....
[youtube]http://www.youtube.com/watch?v=K5jktX4z_rM[/youtube]
https://www.youtube.com/watch?v=K5jktX4z_rM
Vid....
- agent_orange
- Epic Poster
Hmmm really like that!
Well i managed to get some more work done on her....service water pump 'belts and seals etc,,,attacking minor surface rust, rubbing down all the brackets ,pulleys ,nuts and bolts if none could be swapped for new and painted, hoses, alternator hinge bolt,, wiring, re-route and new connections added , New alloy Rad, fabricated new brackets for the fans, need to swap out the manifold/down pipe and mid section for a Mk 2.5 system, finish wiring in the fans and temp sensor, crack on with surface rust , spray the beat rush slam panel ,rocker cover and inlet...so i can move onto the next stage...
Big shout to Andrew Stott Mr Autolinkmx5 for gett some bits out to me super quick and Chris Hay for going well out of his way for me for two 2.5 doors(will come to light latter in this build/renovation)
Anyway some pics...
Anyway some pics...
- 20180706_124602.jpg (569 KiB) Viewed 14940 times
- 20180704_143726.jpg (704.98 KiB) Viewed 14940 times
- 20180704_143740.jpg (699.4 KiB) Viewed 14940 times
- 20180704_143808.jpg (704.22 KiB) Viewed 14940 times
- 20180704_203315.jpg (635.05 KiB) Viewed 14940 times
- 20180704_203329.jpg (596.89 KiB) Viewed 14940 times
- 20180704_213504.jpg (437.2 KiB) Viewed 14940 times
- 20180704_213513.jpg (449.3 KiB) Viewed 14940 times
- 20180704_213822.jpg (609.56 KiB) Viewed 14940 times
- 20180704_214235.jpg (595 KiB) Viewed 14940 times
- 20180705_090212.jpg (702.29 KiB) Viewed 14940 times
- 20180705_090221.jpg (687.97 KiB) Viewed 14940 times
- 20180705_092542.jpg (642.11 KiB) Viewed 14940 times
- 20180705_092556.jpg (591.68 KiB) Viewed 14940 times
- 20180705_094436.jpg (512.68 KiB) Viewed 14940 times
- 20180705_094441.jpg (592.05 KiB) Viewed 14940 times
- 20180705_094450.jpg (654.61 KiB) Viewed 14940 times
- 20180705_103923.jpg (728.61 KiB) Viewed 14940 times
- 20180705_103927.jpg (646.61 KiB) Viewed 14940 times
- 20180705_103935.jpg (435.21 KiB) Viewed 14940 times
- 20180705_103939.jpg (591.02 KiB) Viewed 14940 times
- 20180705_103946.jpg (647.83 KiB) Viewed 14940 times
- 20180705_103953.jpg (514.98 KiB) Viewed 14940 times
- 20180705_105049.jpg (467.56 KiB) Viewed 14940 times
- 20180705_105053.jpg (561.21 KiB) Viewed 14940 times
- 20180705_105116.jpg (649.59 KiB) Viewed 14940 times
- 20180705_111805.jpg (556.43 KiB) Viewed 14940 times
- 20180705_111810.jpg (619.26 KiB) Viewed 14940 times
- 20180705_111825.jpg (702.11 KiB) Viewed 14940 times
- 20180705_163621.jpg (741.6 KiB) Viewed 14940 times
- 20180705_163626.jpg (584.58 KiB) Viewed 14940 times
- 20180705_163632.jpg (700.71 KiB) Viewed 14940 times
- 20180705_163638.jpg (674.5 KiB) Viewed 14940 times
- 20180705_163647.jpg (584.44 KiB) Viewed 14940 times
- 20180705_163652.jpg (623.8 KiB) Viewed 14940 times
- 20180705_163656.jpg (432.85 KiB) Viewed 14940 times
- 20180705_163706.jpg (638.88 KiB) Viewed 14940 times
- 20180705_163715.jpg (665.29 KiB) Viewed 14940 times
- 20180705_190523.jpg (627.91 KiB) Viewed 14940 times
- 20180705_190529.jpg (670.21 KiB) Viewed 14940 times
- 20180705_190537.jpg (704.88 KiB) Viewed 14940 times
- 20180705_190721.jpg (478.02 KiB) Viewed 14940 times
- 20180706_083049.jpg (633.77 KiB) Viewed 14940 times
- 20180706_083107.jpg (687.34 KiB) Viewed 14940 times
- 20180706_083128.jpg (581.21 KiB) Viewed 14940 times
- 20180706_100430.jpg (644.34 KiB) Viewed 14940 times
- 20180706_100439.jpg (646.88 KiB) Viewed 14940 times
- 20180706_100445.jpg (673.14 KiB) Viewed 14940 times
- 20180706_100450.jpg (646.35 KiB) Viewed 14940 times
- 20180706_100513.jpg (669.09 KiB) Viewed 14940 times
- 20180706_100522.jpg (657.98 KiB) Viewed 14940 times
- 20180706_100527.jpg (677.34 KiB) Viewed 14940 times
- 20180706_103550.jpg (691.43 KiB) Viewed 14940 times
- 20180706_124341.jpg (624.73 KiB) Viewed 14940 times
- 20180706_124348.jpg (664.23 KiB) Viewed 14940 times
- 20180706_124353.jpg (695.59 KiB) Viewed 14940 times
- 20180706_124422.jpg (724.16 KiB) Viewed 14940 times
- 20180706_124429.jpg (738.98 KiB) Viewed 14940 times
- 20180706_154945.jpg (670.22 KiB) Viewed 14940 times
- 20180706_154955.jpg (661.31 KiB) Viewed 14940 times
- 20180706_160157.jpg (579.44 KiB) Viewed 14940 times
- 20180706_160209.jpg (612.71 KiB) Viewed 14940 times
- 20180706_160226.jpg (645.71 KiB) Viewed 14940 times
- 20180706_175223.jpg (637.99 KiB) Viewed 14940 times
- 20180706_175425.jpg (665.87 KiB) Viewed 14940 times
- 20180706_175431.jpg (629.84 KiB) Viewed 14940 times
- 20180706_184657.jpg (603.36 KiB) Viewed 14940 times
- 20180706_190208.jpg (655.11 KiB) Viewed 14940 times
- 20180706_190214.jpg (607.65 KiB) Viewed 14940 times
- 20180706_190222.jpg (669.73 KiB) Viewed 14940 times
- 20180706_190315.jpg (669.29 KiB) Viewed 14940 times
- 20180706_191027.jpg (702.04 KiB) Viewed 14940 times
- 20180706_191042.jpg (792.97 KiB) Viewed 14940 times
- 20180706_213923.jpg (604.59 KiB) Viewed 14940 times
- 20180706_213928.jpg (637.51 KiB) Viewed 14940 times
- 20180707_092521.jpg (817.13 KiB) Viewed 14940 times
- 20180707_092527.jpg (906.57 KiB) Viewed 14940 times
- 20180707_092533.jpg (852.29 KiB) Viewed 14940 times
- 20180707_105239.jpg (806.24 KiB) Viewed 14940 times
- 20180707_105245.jpg (802.3 KiB) Viewed 14940 times
- 20180707_113153.jpg (595.1 KiB) Viewed 14940 times
- 20180707_113158.jpg (651.33 KiB) Viewed 14940 times
- 20180707_153931.jpg (546.77 KiB) Viewed 14940 times
- 20180707_153941.jpg (629.28 KiB) Viewed 14940 times
- 20180707_153947.jpg (596.06 KiB) Viewed 14940 times
- 20180707_153953.jpg (582.34 KiB) Viewed 14940 times
- 20180707_154003.jpg (746.06 KiB) Viewed 14940 times
- 20180707_154007.jpg (742.22 KiB) Viewed 14940 times
- 20180707_154052.jpg (622.67 KiB) Viewed 14940 times
- 20180707_154111.jpg (903.01 KiB) Viewed 14940 times
- 20180707_154115.jpg (904.96 KiB) Viewed 14940 times
- 20180707_154132.jpg (659.91 KiB) Viewed 14940 times
- 20180707_175926.jpg (584.44 KiB) Viewed 14940 times
- 20180707_175935.jpg (651.72 KiB) Viewed 14940 times
- 20180707_175940.jpg (594.44 KiB) Viewed 14940 times
- 20180707_175944.jpg (624.45 KiB) Viewed 14940 times
- 20180707_175952.jpg (608.3 KiB) Viewed 14940 times
- 20180707_175957.jpg (577.61 KiB) Viewed 14940 times
- 20180707_180002.jpg (624.54 KiB) Viewed 14940 times
- 20180707_200009.jpg (657.54 KiB) Viewed 14940 times
- 20180707_200019.jpg (592.91 KiB) Viewed 14940 times
- 20180708_140101.jpg (666.35 KiB) Viewed 14940 times
- 20180708_140105.jpg (697.96 KiB) Viewed 14940 times
- 20180708_140110.jpg (613.76 KiB) Viewed 14940 times
- 20180708_140918.jpg (655.37 KiB) Viewed 14940 times
- 20180708_140923.jpg (568.48 KiB) Viewed 14940 times
- 20180708_191739.jpg (630.87 KiB) Viewed 14940 times
- 20180708_191755.jpg (558.36 KiB) Viewed 14940 times
- 20180708_191801.jpg (569.5 KiB) Viewed 14940 times
- 20180708_191805.jpg (491.76 KiB) Viewed 14940 times
- 20180708_191814.jpg (649.41 KiB) Viewed 14940 times
- 20180708_191819.jpg (635.91 KiB) Viewed 14940 times
- 20180708_191830.jpg (687.09 KiB) Viewed 14940 times
- 20180708_191837.jpg (628.31 KiB) Viewed 14940 times
- 20180708_191844.jpg (685.48 KiB) Viewed 14940 times
- 20180708_191858.jpg (651.53 KiB) Viewed 14940 times
- 20180708_191907.jpg (671.36 KiB) Viewed 14940 times
- 20180708_191914.jpg (684.88 KiB) Viewed 14940 times
Fans all wired in and temp sender pre connected....
- 20180709_212906.jpg (531.94 KiB) Viewed 14923 times
- 20180709_212912.jpg (524.15 KiB) Viewed 14923 times
- 20180709_212925.jpg (660.67 KiB) Viewed 14923 times
- 20180709_212941.jpg (556.02 KiB) Viewed 14923 times
- 20180709_212949.jpg (540.05 KiB) Viewed 14923 times
- 20180709_213310.jpg (607.59 KiB) Viewed 14923 times
- 20180709_213317.jpg (611.22 KiB) Viewed 14923 times
- 20180709_213326.jpg (624.07 KiB) Viewed 14923 times
- 20180709_213336.jpg (648.59 KiB) Viewed 14923 times
- 20180709_213349.jpg (602.27 KiB) Viewed 14923 times
Been tied up with everyone elses roadsters so very little is moving.....i have fabricated a new diagnostic bracket to relocate to a better place, more on that later...i managed to deep clean the montana carpet ready for the full interior swap, removed all the sound deadening to clean and re stuck back on when dry....tester colur for the inlet, rocker cover and slam panel is good, i did start to paint the rocker cover until a nat decided it liked it and silicon came from some where, so had to start againn more on that later....
And then re gluing the sound deadening back on.....
And thats it for the miunte....
fitted a new roof in cream with a Mk 2.5 NB rain rail that will match the montana interior...rear interior section all swapped out and seats in,,,just the carpet to swap,dash and door cards....door cards are from a Mk 2.5 NB and with her being a Mk2 NB the door release handle sits in a different place so two knackered Mk 2.5 doos bought and butchered for parts, so a little cutting out and welding will be needed plus making up some new pull rods for the Mk 2 NB doors, more on that later...
So BlackYB popped over with his good lady today for a run out and talk cars, dropped his headrest speakers in while he was here, great to catch up, and it was a lovely day so jumped on opportunity and got the Rocker cover painted .....
Bry....here are some pics and a vid buddy....inlet and slam panel next in the same colour Sparkle Blue Pearl with a black base coat....
Click on the you tube vid below .....
https://youtu.be/jpKT6AHWM2s
- 20180905_150546.jpg (611.91 KiB) Viewed 14682 times
- 20180905_151420.jpg (630.12 KiB) Viewed 14682 times
- 20180905_151427.jpg (588.27 KiB) Viewed 14682 times
- 20180905_151435.jpg (628.76 KiB) Viewed 14682 times
- 20180905_151439.jpg (675.88 KiB) Viewed 14682 times
- 20180905_151444.jpg (704.22 KiB) Viewed 14682 times
- 20180905_151448.jpg (666.93 KiB) Viewed 14682 times
- 20180905_151513.jpg (614.47 KiB) Viewed 14682 times
- 20180905_151519.jpg (633.62 KiB) Viewed 14682 times
- 20180905_151557.jpg (623.3 KiB) Viewed 14682 times
- 20180905_151656.jpg (601 KiB) Viewed 14682 times
- 20180905_151700.jpg (599.57 KiB) Viewed 14682 times
- 20180905_151705.jpg (632.18 KiB) Viewed 14682 times
- 20180905_151709.jpg (635.56 KiB) Viewed 14682 times
- 20180905_151714.jpg (630.6 KiB) Viewed 14682 times
- 20180905_151718.jpg (593.03 KiB) Viewed 14682 times
- 20180905_151722.jpg (596.78 KiB) Viewed 14682 times
- 20180905_151726.jpg (592.67 KiB) Viewed 14682 times
- 20180905_151735.jpg (701.11 KiB) Viewed 14682 times
- 20180905_190049.jpg (502.57 KiB) Viewed 14682 times
- 20180905_151810.jpg (655.77 KiB) Viewed 14682 times
Good to have a catch up with Mm today, talked cars well not so much cars as MX5s.
Good result with the rocker cover but going to wait to see how the one for the redun turns out.
Might just see if the upholsterers who did my seats and door cards can recover the steering wheel to match the rest of the interior unless Mm comes up trumps.
Carry on mending MM.
So finally gotten around to removing and swapping the dash and carpet and fit the new one thanks to Matt and Daryl for helping in a big way, also started on the service etc of the brakes, there is no point at this stage to replace the hoses, pads and disks until the subframes,wishbones,up rights etc and suspension is swapped out also,Which from the pics i am sure you will see why i am not messing with the old units, fit newer better ones and be done,,, so i'll swap them then when the under sealing is done and box sections, damp had been getting in on the drivers side before the HT and new ST was fitted on the drivers side which the sound proofing had held and brought on some minor surface rust, so a quick rub down and paint added while it was out, found my lucky Japanese coin also.
I also took advantage of the dash out and replace the foam seal on the heater trunking seal clip, cleaned and lubed the heater box mechs ...
Had a fun day in between everything else...any way some pics...
- IMG_20181125_121244.jpg (617.67 KiB) Viewed 14461 times
- IMG_20181125_121237.jpg (628.22 KiB) Viewed 14461 times
- IMG_20181125_120556.jpg (470.65 KiB) Viewed 14461 times
- IMG_20181125_120552.jpg (585.76 KiB) Viewed 14461 times
- IMG_20181124_134533.jpg (587.19 KiB) Viewed 14461 times
- IMG_20181124_134522.jpg (695.87 KiB) Viewed 14461 times
- IMG_20181124_134518.jpg (542.56 KiB) Viewed 14461 times
- IMG_20181124_134508.jpg (546.13 KiB) Viewed 14461 times
- IMG_20181125_131141.jpg (489.9 KiB) Viewed 14461 times
- IMG_20181125_131134.jpg (752.83 KiB) Viewed 14461 times
- IMG_20181125_133454.jpg (552.18 KiB) Viewed 14461 times
- IMG_20181125_134725.jpg (569.35 KiB) Viewed 14461 times
- IMG_20181125_101638.jpg (592.31 KiB) Viewed 14461 times
- IMG_20181125_101029.jpg (788.6 KiB) Viewed 14461 times
- IMG_20181118_115750.jpg (547.04 KiB) Viewed 14461 times
- IMG_20181118_115745.jpg (590.45 KiB) Viewed 14461 times
- IMG_20181118_115737.jpg (584.4 KiB) Viewed 14461 times
- IMG_20181118_115723.jpg (557.47 KiB) Viewed 14461 times
- IMG_20181118_115719.jpg (575.13 KiB) Viewed 14461 times
- IMG_20181118_115714.jpg (570.42 KiB) Viewed 14461 times
- IMG_20181117_151635.jpg (539.24 KiB) Viewed 14461 times
- IMG_20181117_151631.jpg (608.87 KiB) Viewed 14461 times
- IMG_20181117_151614.jpg (600.02 KiB) Viewed 14461 times
- IMG_20181117_151548.jpg (508.54 KiB) Viewed 14461 times
- IMG_20181117_151540.jpg (550.54 KiB) Viewed 14461 times
- IMG_20181117_151530.jpg (538.65 KiB) Viewed 14461 times
- IMG_20181117_151518.jpg (640.54 KiB) Viewed 14461 times
- IMG_20181117_151512.jpg (686.1 KiB) Viewed 14461 times
- IMG_20181117_142119.jpg (768.23 KiB) Viewed 14461 times
- IMG_20181117_140652.jpg (648.8 KiB) Viewed 14461 times
- robabarker
- Regular
Reminds me I still need to paint my callipers, think I'll sort out some braided hoses at the same time.
MM-tinkered '98 Roadster RS
New S/steel zorst fitted...de-cat...had to cut off the cats studs had to be cut off so the old system could be removed from the down pipe..and as i was under there i removed the heat shields 10mm head bolts to be greased and replaced with new...the gearbox heat shield but up the biggest fight trying not snap the bolts and brackets....
Manged to save everything and save the heat shield..painted it and refitted...
Rear brakes next..
*****Start from the bottom pic...****
Rear brakes next..
- IMG_20181224_141130.jpg (200.88 KiB) Viewed 14306 times
- IMG_20181224_141056_1.jpg (422.9 KiB) Viewed 14306 times
- IMG_20181224_141042.jpg (474.17 KiB) Viewed 14306 times
- IMG_20181224_141036.jpg (449.68 KiB) Viewed 14306 times
- IMG_20181224_141015.jpg (587.96 KiB) Viewed 14306 times
- IMG_20181224_141010.jpg (674.76 KiB) Viewed 14306 times
- IMG_20181224_120321.jpg (804.4 KiB) Viewed 14306 times
- IMG_20181224_120317.jpg (781.69 KiB) Viewed 14306 times
- IMG_20181224_120000.jpg (749.8 KiB) Viewed 14306 times
- IMG_20181224_115951.jpg (646.94 KiB) Viewed 14306 times
- IMG_20181224_115942.jpg (674.49 KiB) Viewed 14306 times
- IMG_20181224_115935.jpg (733.59 KiB) Viewed 14306 times
- IMG_20181224_115928.jpg (656.67 KiB) Viewed 14306 times
- IMG_20181224_115923.jpg (758.91 KiB) Viewed 14306 times
- IMG_20181224_115851.jpg (586.32 KiB) Viewed 14306 times
She is going to take a different route, Mk 2 front (RS front with OE spots)going back on with a OE lip/chin spoiler..and Morette headlight units, and the boot lid will be a Mk 2.5 OE boot lip spoiler....
Filling the old number plate holes...
- IMG_20190217_173208.jpg (445.56 KiB) Viewed 14128 times
- IMG_20190217_173153.jpg (361.6 KiB) Viewed 14128 times
- IMG_20190217_173148.jpg (362.02 KiB) Viewed 14128 times
- IMG_20190217_173143.jpg (427.86 KiB) Viewed 14128 times
- IMG_20190217_173137.jpg (462.58 KiB) Viewed 14128 times
- IMG_20190217_173128.jpg (429.72 KiB) Viewed 14128 times
- IMG_20190217_173123.jpg (370.1 KiB) Viewed 14128 times
- IMG_20190217_171015.jpg (479.58 KiB) Viewed 14128 times
- IMG_20190217_171008.jpg (475.86 KiB) Viewed 14128 times
- IMG_20190217_170948.jpg (665.77 KiB) Viewed 14128 times
- IMG_20190217_170941.jpg (748.91 KiB) Viewed 14128 times
- IMG_20190217_171057.jpg (733.59 KiB) Viewed 14128 times
- IMG_20190217_170926.jpg (456.38 KiB) Viewed 14128 times
Not much happening at the minute with her as bad back and other priorities have taken over....
We just fitted the style bar to her...
Derusted the front fog light brackets ready for paint and re install...
- IMG_20190421_151021.jpg (444.94 KiB) Viewed 13789 times
- IMG_20190421_151022.jpg (450.73 KiB) Viewed 13789 times
