Hi all.
Not sure this is the right place to post this so feel free to move it.
I'm looking at getting a small active (built in amplifier) "underseat" sub for the 5. I know it won't fit under the seat so I'm going to mount it behind the drivers seat, I'm a midget so there's plenty of space back there
I've just got a couple of questions:-
1). Can it be screwed to the bulkhead without puncturing the fuel tank (not necessarily the same answer as can I do it without puncturing the tank! )? If not then I'll probably use velcro and stick it to the carpet (which will in turn probably need sticking to the car better), or maybe even under the carpet straight to the metal. I'm just not sure about the amp getting too hot doing this?
2). The RCA and remote switch etc I'll run under the center consol, that bit's easy enough, but where can I run a live feed from the battery to the passenger compartment? I'm assuming if I actually went out and looked I could follow some original wiring, but I'm at work trying to look like I'm working...
3). And lastly, has anyone done similar and whats it like? I'm not after bone shattering bass, but would like to be able to take a bit off bass off my door and head rest speakers (upgraded not standard) so I could turn them up a bit more with the roof down on the motorway (and maybe occationally in Tesco car park... lol).
Cheers
Bob
Amplifier fitting questions
- bob_drinks_beer
- Just Run In
I've a 2.5, the battery is in my boot, it's easy to pop a cable through the tunnel that runs from the boot area to behind the drivers side carpet, behind the seat.
Pop the plastic trim in the boot out, and remove the poppers in the cabin, simples.
I have an amp in my tunnel, no sub, so I can't help on that part.
I'm learning.........Slowly!
- binarypunk
Re: Amplifier fitting questions
Really, any cabin electrics should be run off the ROOM fuse in the fusebox. It is also very simple to run a wire from there.
If not using the room fuse, and connecting directly to the battery, you must use a suitably sized inline fuse for protection, else a short will cause your battery to blow up.
As above, my power cable has an inline fuse, located near the battery for easy fuse swopping :)
- bob_drinks_beer
- Just Run In
binarypunk wrote:Really, any cabin electrics should be run off the ROOM fuse in the fusebox. It is also very simple to run a wire from there.
Yeah I wouldn't run anything without a fuse. I had an old Rover P6 loom turn all black and crispy because there were only about 3 fuses on the whole car... it all got replaced and every circuit went on a separate fuse and much of it got relays fitted as well.
Where is the room fuse and what rating is it? I'll probably need something fairly hefty which is why I am planning on going straight from the battery.
