This afternoon we had a Mk4 on the lift to look at the possible need for topping up the factory underseal.
First thoughts are there are a good few areas that need a further application of Goo.
Behind rear bumper
and again behind the rear bumper
The rear bulkhead
other side
Beside rear exhaust box
Typical subframe pick up point lack of underseak coating.
Towards the rear on both sides is this access hole
There is a very large area in there with no underseal see this picture from the scope
Again the chassis rail / subframe pick up point.
This plastic sill protector covers a section of sill with no underseal, this needs sorted in order not to be a home for water and mud which is not a cars best friend.
ND4 Underside
ND4 Underside
2008 Mk3 Copper Red gone
2018 Mk4 GT+ Red
2018 Mk4 GT+ Red
Re: ND4 Underside
Well done that man.
Re: ND4 Underside
Thanks Eddie
I have one hitting here in a couple of weeks for attacking with underseal protection..
Re: ND4 Underside
The hole I refered to on each side just above the boroscope picture should have been covered with a rubber plug. Looking at the Mazda portal I reckon but check with your Mazda garage it is Part Number
FD01-56-051.
You need two, they are with the owners manual in some cars delivered to the US. The cost is £4.61 plus vat and I think that is each.
Check if they are with your owners manual and if they are not in there and the hole is not covered tell your Mazda dealer to get them at Mazda's cost.
FD01-56-051.
2018 Mk4 GT+ Red
2018 Mk4 GT+ Red
Re: ND4 Underside
A few more before we started to underseal on Thursday.
Under the front wings after removal of the two piece wheel arch liner.
Front chassis rail
The other side
Other parts of the area under the front wing
Under the rear arches after removing the rear wheel arch liner
The rear bulkhead and the area where the rear cabin drains discharge rainwater.
Front chassis rail
The other side
2018 Mk4 GT+ Red
2018 Mk4 GT+ Red
Re: ND4 Underside
Well they won't take long to rot out, Paula if you are following this i will hit your asap buddy.
Re: ND4 Underside
Wayne.
The only one little issuse when taking covers off is at the back.
The rear wheel arch protector is in two pieces. The front bit is woven and the rear part is plastic.
The rear section has to be slid off as it is also held on by four internal slide surfaces picutre here and there is one small cross head to come out on the rear part as well.
This little corner undertray at each front corner held on by 8mm AF bolts and about 5 plastic clips is connected to about 8 inches of wheel arch liner at the front The rear bit of the front liner is only held on by plastic clips but have a look at how it fits to the wing return as it is easy to put it back incorrectly.
Both pieces of front wheelarch liner off the car.
2018 Mk4 GT+ Red
2018 Mk4 GT+ Red
Return to “Mk 4, 2015 to date (ND)”
