Dyno services...
BenF
Dyno services...
Postby BenF » Tue Jan 13, 2015 12:17 pm
Our Heenan & Froude WB dyno (engine not chassis) is now up and running, in the purpose built dyno cell!
We have the capability to run-in & power-run engines and check/certify on standard peripherals before dispatch or collection for ratings up to 230lb/ft. We can also vary the environment depending intended uses - higher/lower atmos. pressure, higher temp countries, lower temp countries, prolonged high-heat (enduro) etc.
Usually we dyno our own builds, but if you're looking for dyno time for your own build then give us a shout and we can talk it through :coffee:
Mapping is currently limited to adjustment to existing maps/retuning after modification and for DTA Pro series mainly, but we have five clients (2x turbo, 3x supercharger conversions) for MS2 tuning on the bench, and have Omex capability by prior arrangement if required.
Contact us to discuss your needs! :handgestures-thumbup:
Return to “Basset Down Balancing”
