Postby Mazda Mender » Mon May 17, 2021 7:01 am
Not really what i have done to her , but i have a MK 1 1.6 here with a running issue ,which is on the inlet, so dug out a full inlet to swap out so i can test it on her and pressure test the inlet i think is at fault once her, so did a deep clean on my tester , and well you know how it goes, ended up stripping it all down, wire brushing ,sanding etc good wipe down with brake cleaner ,painted everything and rebuilt it with copper grease and red rubber grease, and on build up after everything was done and away , i found a 10mm bolt i missed, grrrrrrrrr, it was like a kick in the n*ts, it will niggle me now until i sort it , and then also change the devil hose clips for some newer ones, my good lady asked why i had gone into so much detail when it was a "tool" for testing with, its clean for use and i know it works, and "why not".
So i will now be doing another Seven ready for testing with , as these get older different issues are showing up, so makes sense for me to do so and have them sat on a shelf ready with all the other testers when the diagnostic reader tells me nothing as in this case and many others i have had to deal with..
MK 1 1.6 Auto
MK 1 1.8 manual
MK 1 1.8 Auto
MK 2/2.5 1.6 manual
Mk 2 1.8 manual
Mk 2 1.8 Auto
MK 2.5 1.8 manual
- 20210515_162208.jpg (859.11 KiB) Viewed 6832 times
- 20210515_162210.jpg (866.29 KiB) Viewed 6832 times
- 20210515_162912.jpg (839.91 KiB) Viewed 6832 times
- 20210515_164059.jpg (885.3 KiB) Viewed 6832 times
- 20210515_164104.jpg (869.74 KiB) Viewed 6832 times
- 20210515_164140.jpg (860.21 KiB) Viewed 6832 times
- 20210515_170246.jpg (866.84 KiB) Viewed 6832 times
- 20210515_170251.jpg (539.16 KiB) Viewed 6832 times
- 20210515_192433.jpg (652.27 KiB) Viewed 6832 times
- 20210515_192446.jpg (664.25 KiB) Viewed 6832 times
- 20210516_190733.jpg (707.52 KiB) Viewed 6832 times
- 20210516_190739.jpg (608.55 KiB) Viewed 6832 times
- 20210516_190743.jpg (686.19 KiB) Viewed 6832 times
- 20210516_190746.jpg (681.34 KiB) Viewed 6832 times
- 20210516_203130.jpg (531.48 KiB) Viewed 6832 times
- 20210516_203134.jpg (636.44 KiB) Viewed 6832 times
- 20210516_203141.jpg (653.68 KiB) Viewed 6832 times
- 20210516_203309.jpg (652.66 KiB) Viewed 6832 times
- 20210516_203317.jpg (601.67 KiB) Viewed 6832 times
- 20210516_203323.jpg (599.01 KiB) Viewed 6832 times
- 20210516_203327.jpg (591.37 KiB) Viewed 6832 times
- 20210516_203336.jpg (569.38 KiB) Viewed 6832 times
- 20210516_203356.jpg (546.15 KiB) Viewed 6832 times
- 20210516_203401.jpg (369.55 KiB) Viewed 6832 times
- 20210516_203431.jpg (628.85 KiB) Viewed 6832 times
