On early MK2's (UK and Jap) Mazda fitted a cut off switch to the hood frame, effectively cutting off the power(Earth) to the Heated Rear Window when the soft top is lowered. However many owners have come across the problem of the switch staying off when the top is put back up, particularly when a hard top has been on for some time.
A cure for the problem, remember that later MK2's and MK2.5's did not have it fitted.
I was removing the hood skin, so i did this at the same time, you DO NOT NEED to remove the hood to do this.....
LEFT CLICK ON THE PICTURES TO ENLARGE
The kill/cut out switch in place on the passenger side
Unplug and remove the screw from the switch which loops the earth.
As you can see all the trim is off which makes it easier to see, this can all be done by just removing the rear deck carpet only, there is NO NEED to remove all the trim and hood/hood frame.
Next cut the two earth loop wires.
Strip the plastic wire coat back.
Solder the wires together for best strong result and cover in heat shrink or electrical tape.
Tape up the extra back into the loom.
And this is what as been cut out.
Poorly thought out design gone, no problems for the future.
Early MK2 heated rear window cut out switch
