********* CLICKING ON THE IMAGES WILL ENLARGE THEM FOR BETTER VIEWING*********
Images have been taken from a MIata manual so mirror image the cab for location....
MK 1 NA 1989 > 1997
* 13745.... BRACKET,RELAY
* 66830B.... UNIT,FLASHER
* 67650.... BOX,CONTROL-A.B.S.
* 677403.... RELAY,N.O.
* 67741.... CONNECTOR,SHORT
* 677C0.... RELAY,RETRACTOR-COWL PANEL
* 677T0.... UNIT,TIMER-REAR DEFG.
* 679A1A.... BRACKET,RELAY
* 679A2.... COVER,RELAY
* 90906.... NUT,FLANGE
* 99175.... SCREW,TAPPING
MK 2/ 2.5 NB 1998 > 2005.....
* 18821.... RELAY,FUEL PUMP
* 66438.... RELAY,HORN
* 67521A.... BRACKET
* 67560B.... UNIT,CENTRAL PROCESSING
* 67591.... BRACKET
* 675D0.... UNIT/TRANSMITTER,KEYLESS
* 675DZ.... KEYLESS ENTRY SET
* 675G2.... UNIT,IMMOBILIZER
* 675RY.... TRANSMITTER SET,KEYLESS
* 67830.... UNIT,DOOR LOCK & TIMER
* 67970.... BRACKET,RELAY
* 679C1.... BRACKET,RELAY
* 90786.... SCREW & WASHER,TAPPING
* 90901.... NUT
Mk 3 NC 2006 > 2015...
* 66939A.... COIL,ANTENNA-IMMOBILIZER
* 675D2.... UNIT,KEYLESS ENTRY
* 675DZA.... RECEIVER,KEYLESS
* 67664.... BRACKET
* 676B1.... BUZZER,KEYLESS
* 679A0.... BRACKET & RELAY
* 67SB0.... SIREN,BURGLAR
* 90720.... SCREW
* 90901.... NUT
Mk 4 ND 2017 >********..........
If you have found this guide to be useful, helpful or as helped you with your roadster with saving on garage costs , please consider making a donation to keep these gates available for others and so new info can still be added to carry on helping.
Identifying the relays and where Mk 1 NA/2/2.5NB/3 NC/4 ND
