This is for the early type of switch, i will do one for the later type to.
If the window goes down put not up or the other way around or it will move with a wiggle of the switch, then it is carbon build up on the contacts with in the switch and is just a simlpe case of taking it aprart and giving them a good clean...
First remove the small phillips head screw from the centre of the board.....
Then pop the plasitc locking lugs that hold the board to release it from the body with the switches....
As you can see the carbon build up is stopping the connections to make a good contact.....
It is just a case of getting a small screw driver and scrape the build up off and then giving the whole thing a wipe over...
And thats it ,put the clean switch contacts back on the board and just push it back to the switch body and listen for the click from all the locking lugs and the just put the center holding screw back in, job done , 10 minutes tops, so go and give it a try
Early MK 1 electric window switch repair
