My recently imported 1.6 Mk1 has a very expensive 'Togichi Fuji Super LSD' which I believe has some sort of clutch arrangment to distribute the torque to the appropriate wheel when required. As it hasn't had an oil change and was starting to give a bit of chatter and judder when pulling away at an angle of travel.
The oil was unknown and I tried the 75w 90 GL5 but that didn't seem to help the chatter very much. After a bit of research I was guided to Castrol Racing limited slip diff oil and also used in conjunction with Redline limited slip diff friction modifier.
https://www.ebay.co.uk/p/Castrol-B373-L ... 7675.l2644
https://www.ebay.co.uk/p/Red-Line-LSD-L ... 7675.l2644
The chatter and judder has completely gone and is now a pleasure to drive off the drive at a 90 degree turn.
2nd Weston Park April 2017
